Which coolant?
31K views 33 replies 17 participants last post by  Halo_2
#1 ·
Hi again,
This is kind of following on from my other post about servicing, but I can't find any recent posts on the subject either so thought I'd ask.
Spoke to my local triumph about the fact that my Speedy is a 2018 model, has only had the first service, but only has 1400 miles on it, and they want £300+ for changing my engine oil, diagnostics, brake fluid flush, and coolant change.
I figured I could do that easily, but he said something about the factory coolant being discontinued, so they have to use an updated coolant now, and seemed quite vague about it.
Is this true? And if so, what coolant is being used now if the stuff in the manual isn't the correct stuff?
#9 ·
Why does it have to be Phosphate free?
A lot of other posts and forums are suggesting Prestone, but they use Phosphates.
Who knew coolant could be so bloody confusing? 😂
There are many articles on this subject on the net. Look some up on Google, interesting and important subject, especially if you care about your engine.
#11 ·
I caved and ordered two bottles of the Hd4x 😒
I spent most of the last two days scouring the Web for info, and the only solid recommendation I could find was Prestone Extended Life coolant, which appears to be unavailable in the UK since I can't find it anywhere this side of the pond, and when i called a prestone and asked them about it, they didn't know what I was talking about and said they only do one coolant.
I'd be interested in a Waterless swap in the future, but at least this will cover me for the next couple of years 🤷‍♂️
#14 ·
Hi again,
Hi again,
I was told by Triumph UK that the HD4X printed in all the Handbooks was discontinued in Jan 2021. As it's completely unavailable there must be something erong with it - why no recall... Handbooks for 2021 still specify it.
#15 ·
not my words.......
Please Note Triumph D2053 OAT is coloured orange compared to the Triumph HD4X OAT which is coloured green. When topping up/replacing with the new coolant (colour orange) check the coolant in the system. You can not mix the HD4X OAT with the new D2053 OAT, The system will need to be drained and flushed through with de-ionised water before filling with Triumph D2053 OAT. The new coolant has a service life of 5 Years.
.........assuming the above is correct - OAT you buy from the shop is always orange. God knows why Triumph originally coloured HD4X green, and why you cant mix the old and new together, even though they are both OAT
#21 ·
#23 ·
Krysztof, after reading your strong statement I felt compelled to do some further research. Every article I read states that car coolant contains silicates among other additives. For motorcycle engines however that is not the case. The following paragraph synthesizes all of what I read.
"What does silicate do in coolant?
Silicate gel buildup greatly reduces heat transfer from the engine castings to the coolant. When the gel coats the temperature sender, engine overheating can take place without notice. Silicate gel also carriers abrasive particles to the water pump, where it wears away pump seals causing leakage and failure."
#27 ·
Coolant for engine is the same for a car vs bike, there is nothing special about a bike.
As long as you get the specs correct to manufacture then your good to go.
**** even engine oil with the correct properties and don’t contain friction modifiers will be fine.
Penrite sells car oils that suit motorcycles as well.
#25 ·
The word PEDANTIC comes to mind after reading all this bu// sh#+, there's probably a guy with a heap of demineralised water and a load of green dye and red dye somewhere laughing his fu@#ing head off and making sh:t loads of money out of it, it's not going to happen in our lifetime guys just enjoy the ride :ROFLMAO:
#28 ·
I do not know who wrote that analysis, but there is a major flaw which somewhat negates to recommendations. I contacted Ken Cummins at Finol and he confirmed that Finol are not the supplier of Triumph's HD4X coolant. He suspects it was Solventis who supply many OEMs with white label coolants and oils. So I am still not sure whether to top up with a P-HOAT or a S-HOAT coolant
#29 ·
"Cooling systems in motorcycles contain more aluminium than the ones in passenger cars. Some even use magnesium. These metals are lightweight yet strong when compared to iron, but on the other hand, they are susceptible to corrosion. Hence, choosing an anti-corrosive coolant is extremely important.
If corrosion occurs in cooling systems of bikes, it would hinder heat transfer, thus increasing the engine temperature tremendously. Even worse, it can clog coolant passages and prevent the flow of coolant, which will also result in overheating.
Hence, to provide the best quality protection, use a special motorcycle coolant or some other coolant that contains highly purified water. Also, make sure the coolant you choose contains additives that are specifically designed for magnesium, aluminium and other metals that are mostly present in motorcycle cooling systems."
Direct quote.
