If you can share a few things about your ownership of the 2017+ Triumph Bonneville Bobber, what would it be? The most liked or hated, share them with every one I am sure you won't be the only one.
If you can share a few things about your ownership of the 2017+ Triumph Bonneville Bobber, what would it be? The most liked or hated, share them with every one I am sure you won't be the only one.![]()
Was the T120 tank swap fairly easy?Hated the tiny tank ~ changed it for T120 one
Headlight ~ changed for 7" led
Indicators/rear light ~ fitted bar end indicators & Thrux R rear light
Cat ~ killed that straight away
Exhausts ~ fitted goldie's
Mudguards ~ lengthened both front & rear, with extra stays
Front brake ~ fitted bigger disc & 6 pot being made
Colour ~ booked in for paintjob
HATE HATE HATE speed restriction ~ too tech for me but am desperately waiting for someone to crack ecu
Really like this bike.
Not too bad, cut rear mounting off, bond flat mounting on to use front seat bolt seat bolt, stretch tank throat on left side a little to avoid crushing wiring, bend sender arm downwards a bit.Was the T120 tank swap fairly easy?
Thanks. Bob
Thanks!Not too bad, cut rear mounting off, bond flat mounting on to use front seat bolt seat bolt, stretch tank throat on left side a little to avoid crushing wiring, bend sender arm downwards a bit.
Usually top up takes around 13 litres.
