Mine is a 2021 model so its "euro-5" compliant. Any Speedmaster prior to this should be Euro 4 which seems to be a little less restrictive about such things as booster plugs (an excellent upgrade to help with lean fuelling) and general tinkering and modification (euro 5 ecus have anti-tampering software). I have read that the ecu will throw an engine management light if you change the front and rear sprocket ratios too much...!
I cant say that ive read of any common faults on the Speedmaster so usual used vehicle checks should be carried out.
Suspension isnt the greatest ive found but there are aftermarket options to consider if the stock setup isnt to your liking.
