1 - 11 of 11 Posts
· Registered
Discussion Starter · #3 ·
At first I thought it was a bolt going through a shaft, but after a closer look, it does seems to be a solid shaft with a 6mm hex socket head. A couple of O-rings stops oil from getting to the plug located on the cover. That shaft does not seem to serve any purpose whatsoever ... so what's it doing there?
Automotive tire Wheel Motor vehicle Gear Bicycle part
Automotive tire Motor vehicle Rim Automotive wheel system Vehicle
· Registered
2020 Bobber Black
That appears to be the balancer shaft. Number 7 are the double O-rings.
Wheel Motor vehicle Font Rectangle Parallel
Reactions: Enoch
· Registered
Discussion Starter · #5 ·
Yup, thanks.
Font Number Screenshot
Any idea why the cover bolt allows access to the 6mm hex head on the end of the shaft? Is there maybe some sort of adjustment factory techs have to perform prior to certifying the engine as properly counter-balanced?
· Premium Member
Yup, thanks.
Balance shafts usually have some sort of preload that puts pressure against the opposing shaft. It’s possible that the hex is for an Allen key so that the preload could be set.
· Registered
2020 Bobber Black
The basic idea of the counterbalance is to quell the vibration inherent with the engine design. The vibration induced in setting the pistons 90 degrees apart is different than the vibrati0on induced when the firing order is 360 degrees like in the old (pre 80's) Bonnevile motors (where both pistons hit TDC simultaneously). That's why the sound of the two bikes is different, different crankshaft firing order.
This is the Bobber crankshaft: Note the crank webs are 270 dgrees (90 degrees) apart. The delay in firing gives a more Harley like exhaust cadence.
Font Auto part Cylinder Art Engineering
The balancer shafts are actually counter-banacers to oppose the rotating mass of the crank pistons and webs. The amount of counterbalance can be tuned to totally eliminate the vibration (removing all motor character as well) or you can adjust the balancer to allow a certain desirable amount of vibration so it feels more "old school." That's why the balancer doesn't get rid of all the vibration it could. The factory 'tunes' the vibration into the machine. When the Bonneville was initially tested back in 2000 the engineers had 100% of the vibration quelled and when they compared the bike's 'feel' to a 1968 Bonneville it didn't feel right. That 1968 vibration was 'tuned' back into it. The 1968 Bonny wasn;t counterbalanced, it used a standard 360 degree crank firing order, where the mass of the pistons was counterbalanced by the crank webs.
· Registered
Discussion Starter · #11 ·
Thanks for the perspective, guys. Very interesting area of engineering, especially when you consider the implications of induced out-of-balance motors to give the rider the 'right' feel.
1 - 11 of 11 Posts
