Hey mates, if you are looking for a suspension upgrade as well, eventually go for this:
https://www.matrisdampers.com/prodotto/senza%20categoria/bonneville-bobber-1200/
I completed the installation of the shock and the fork cartridges these days and so I can report:
The parts are perfectly designed and machined, very high quality, comparable to Öhlins or Wilbers! Plug and play!
Installation of the cartridges is easy going as soon as you have got this fucking original dampers out of the fork tubes!
(This crap is fixed with thread locked bolts through the bottom of the tubes and as soon as you have loosened the bolts using an impact wrench the dampers start to rotate and can hardly be counterholded by means of a custom piece of wood! The trick is to reverse the impact wrench several times, to break the thread locker glue!)
The shock has adjustable rebound and spring load. The fork kit is fully adjustable in spring load, compression (left cartridge) and rebound (right cartridge). All adjustments are on top of the tubes. Any damping characteristics can be adjusted with decent clicks.:grin2:
Can't wait for spring!
Werner Wernersen >
Werner Wernersen >
