What tyre pressure is everyone running in the front tyre that manual says 32 psi that dealer said 36 and on the tire it says 41 the rear tire everyone agrees it's 42 even the tire says 42
I corrected my previous post. Indeed it is 32/42In my manual it's stats 32 for the front and 42 for the rear psi
X1 on this thought.in the bobber black the pressures are different.... 2.3 bar for the front and 2.6 bar for the rear
I drop both my front and rear tire pressures. I feel like the bike handles a little better and the bumps aren't quite as bad on my butt.32 front, 42 rear for every day general riding and commuting, i do drop the rear to about 36 when I'm having to ride with sports bikes just to increase the contact patch with the pegs down in corners trying to keep up.
Personally, I would be to stick to the recommended pressures.I replaced my tires with Shinko tires, Should I still follow the manuals recommended tire pressure?
Would love to see pics of the Shinkos. Any problems installing, as I think they don’t make the exact size, at least not for the rear tire...?
Triumph (for the regular Bobber) quote 32 PSI front & 42 rear. For the BB it’s 32/38.
The pressures written on the side of your tire will be for MAXIMUM pressure, so you don’t want to be near those.
I would stick to 32 front, but drop the rear to 36 or so and see how it feels.
Did you check Shinko’s website or speak to a reseller to try and find out more accurate information?
Sometime recommended pressures do differ by manufacturer.
