1 - 9 of 9 Posts
Hi,
TUNEECU reset adaption looses cruise control, seems it needs to be reactivated.
Error P1575 cruise control disabled until button press sequence completed
All activation tutorials has other Triumph model ones, which has +- buttons, so this tutorials don't work.
What is the sequence for Bobber ?
Thanks,
Key in ignition and bike on (engine Not running)
Activate front brake switch
Rear brake switch
Clutch switch
Twist grip switch (push the throttle in the closed position all the way forward)
Activate cruise on/off switch
I’m pretty sure thats the correct sequence, but it’s been over a year since I did it.
Hope it works for you!!
Rear brake switch
Clutch switch
Full throttle or what this part means ?
What i did:
Pulled front brake,release,back brake release,full throttle, release, cruise on/off
But this doesn't work, tried multiple times.
Roll the throttle FORWARD (away from you while you’re seated on the bike).
It will only roll a small distance but it HAS to be done. Otherwise the sequence is not complete.
Totally understandable! I can’t stand any unnecessary lights illuminated when they shouldn’t be either :wink2:
Hi,
Thanks,
Well shoot, apparently this is still a thing and I can’t get it to reset. I tried exactly what was described below but no luck.
1 - 9 of 9 Posts
