i've never had traction control on any of my previous bikes so i wanted to find out more about what it should and should not be doing when on (which is the normal setting on our bobbers)
the only time i've seen the traction control light go on in the instrument guage and actually feel the cut in power is when going over maybe a really bumpy patch in the road while accelerating. i can feel the engine power drop to keep adequate traction on these areas.
what i've noticed is that sometimes on a straight smooth road, i sometimes can feel the rear tire spinning up when really opening up the throttle (aggressive, but not like super crazy) i check my tire pressures before each ride so i ruled that out. i figured it is probably just areas where the road is a little slick due to oil residue, moisture, etc. however, shouldn't the traction control prevent instances of this from happening where i feel the rear tire spinning in place during hard acceleration? just concerned if by chance my traction control isn't functioning properly.
thanks!
thanks!
