1 - 15 of 15 Posts
Finally found the time and fitted a bigger speedmaster tank to my Bobber, looks amazing and had so many great comments.
Plus extra fuel range always helps, noticed it straight away.
What do you think?
I don’t know what it is but it looks sooo much bigger than stock which is surprising because it’s not much bigger. Maybe the angle.
2017 Triumph Bobber NYC
That looks fantastic and the stripes work really well with those whitewalls. Are you planning an airbox delete as well or just haven't popped the side panels back on?
Beautiful bike and tank. I want to do the same with my bobber. Does the speedmaster fuel tank has to be modified? Or does it fit to the bonneville bobber unmodified?
The tank doesn't have to be modified, but if you want your fuel gauge to be more accurate (not that Triumph fuel gauges are all that accurate anyway), you'd need to replace the fuel sensor from the Bobber one to the Speedmaster one.
Is that 12 litres now? Could you show us a photo of the rear mounting? One more question, is it wider at the rear so that your knees touch the scalloped sides?
1 - 15 of 15 Posts
