1 - 3 of 3 Posts
As the title suggests, I'm getting the Vance and Hines installed this week and I currently run with the Booster Plug. Should I leave it in place while they remap the ecu for the V&H?
I can see how it would make a difference since the dealer is remapping the ECU and the plug is separate.
Your Thoughts
Cheers
Gary
Won’t make a difference. The booster plug is not making changes to the ecu. It is just manipulating sensor readings. You will be fine by leaving it in. I did.
Perfect, thanks
That's what I figured but thought I would check with someone that has done it
1 - 3 of 3 Posts
