The Rizoma signals have running lights. I installed the S club in the rear. Gonna put the L club on the front.
The OEM headlight has a running light in it. It's a small light inside the housing. So the wiring for running lights in the front is there. You would just need signals that have running light option and splice into it. It's the yellow wire. The black is the ground. Coming out of the OEM headlight are 5 wires. 2 blacks that are spliced together (ground), yellow (running), blue with white stripe (high beam), blue with red stripe (low beam)
