1 - 2 of 2 Posts
Hi.
I've fitted aftermarket LED indicators to my 2018 Bobber. The ones on the rear are multi-function brake/tail/indicator lights.
They all work correctly but I have the dreaded hyperflash. I'd read on this forum that you can change the ECU through the menu to work with LED indicators but I've tried all 4 settings and it's made no difference at all.
I'm guessing I need resistors but have no idea whether I need them on all 4 indicators or how I determine what size they need to be.
Any advice would be much appreciated. Thanks :)
see above
I was able to just fit resistors to the rear indicators to solve the problem.
what is the wattage of each indicator - are the front and rears the same?
1 - 2 of 2 Posts
