1 - 15 of 15 Posts
Hi, I managed to take off the right hand side cover easily.
the left side one seems stuck. I don’t dare using more force. Does it come loose the same way, pulling out the bottom?
I am taking them off in order to give them a thorough polish and coating.
Thanks,
ABV
Yep, if they haven't been removed for a while they can be worryingly tough to pull out...
Reactions: ABV2020
Read Only
Anybody ever tried any form of lubrication on the pins? I suspect a petroleum based lubrication might deteriorate the rubber but is there anything else that might prevent the side panels from sticking?
Millers red rubber grease 👍
Silicon grease...
I’ve used petroleum jelly on parts like this for years.. never had a problem
Silicone grease works great, doesn't gel and remains viscus. MilSpec, been using it for centuries, is non reactive with nil detriment to natural rubber & plastics.
Don't be over zealous in application, just a smear.
Thanks,
ABV
Yes - a bit of force may be required :)
1 - 15 of 15 Posts
