1 - 16 of 16 Posts
Please excuse my ignorance, however I am in the process of installing the short front fender, and for the love of me cannot figure out how to take off the front wheel. Is there a special tool for removing the axel tube?
Yes. No other way. Good news: it take about ten minutes. I take mine on and off regularly.
Hello there
You have changed the pipes and headlight. Ditched the side panels and added (K&N?) filters. Did you experience many problems doing this? Any benefits? What are the pipes?
Thanks
Banned
old thread I know but didn't want to start another....how do you jack up bike to remove front wheel ....changed wheels on dozens of bikes but the Bobber seems to tip forward when I put the jack under the subframe...where is the safest sweet spot??
Banned
I used a scissor jack as far forward of the frame as I could. Lifted until the wheel just cleared the floor. No issues.
ok cheers...that area looked a bit delicate to me ....did your scissor jack go under it or di you improvise with scaffold boards under front wheel to get the sub frame up a bit?
Is it absolutely necessary to remove both front disc brakes in order to remove the wheel? I’d like to remove the wheel in as few a steps as possible as I’m just replacing the front fender.
1 - 16 of 16 Posts
