1 - 4 of 4 Posts
On the new bobber 22+ to remove the seat
The bracket the seat sits on has two bolts either side and one under the tank.
There is a collar one side does the other side have a washer?
Triumph-parts-UK says yes
World of triumph says no
Local dealership says yes the other says no.
I think the washer their referring to is for the top bolt?
Hello, I have removed the seat on my Bobber several times for service and to replace the seat pad. There are no washers on the side or front mounting/securing bolts. However, the fitting of the sleave/collar to the inner side of the right-hand mount is important. There are just the 2 washers on the underside of the seat pan for the seat adjustment bolts. See the attached parts list, hope that helps.
Discussion Starter · #4 ·
Also with the seat removed I noticed, with the stock seat the small Torx screw that goes from the metal plate to the seat….the front one doesn’t screw all the way down almost like it’s too long? All the other do screw down
Bolt 11 I'm talking about T3330444
1 - 4 of 4 Posts
