1 - 20 of 21 Posts
It is the LOW PRESSURE OIL LAMP and means absolutely NOTHING if the engine isn’t running:
The low oil pressure warning light will illuminate if the ignition is switched ON without running the engine.
Only worry if it comes on when the ENGINE is running.
Isn't using the kill switch a dangerous choice with regards to shutting down as when using the ignition switch the bike will go through a set procedure, whereas the kill switch will overide this and could potentially cause damage? Maybe me being an over cautious engineer 🤷‍♂️
I’ve always just used the kick stand while in gear and then just remove the key.
Never had an issue (I’ve had quite a few bikes) and come to think of it, I can ever remember using the kill switch. Ever.
(*apart from starting the engine, of course !)
Its also a habit as I always leave my bike in gear when parked.
I'm the opposite - I've never used the key to turn off the engine! I've always gone kill switch first then key. No issues so far - what an I missing out on? 😋
I don’t think you’re missing anything. We all just have our own way of stopping the engine/bike.
Go by the manual or use the kick stand to stop the engine running like I do. Your bike, your choice.
Haha! I’m far from being a source of all knowledge. But I can honestly say that if I would have had any mishaps occur from the way I turn off my engine, I would gladly share it with the forum to save it from happening from anyone else.
Judging from the YouTube video, it looks like this is time I got lucky and was correct with my info >:)
Which bike stopped the engine by lowering the kick stand 40 years ago?:confused:
Dang if I can remember. :| When you get my age you just make up stuff. :laugh:
I do remember that BMW's kick stand popped up if you unloaded it. I watched a guy who was not familiar with motorcycles drop a BMW after the kick stand popped up. He took out a whole row of bikes in a domino effect. It was a hoot to watch. >:) I think the ignition/kickstand interlock started shortly after that. 30 years ago?? 25 years ago??
Anyway, as soon as you could stop a bike by putting down the kick stand that's what I started doing.
1 - 20 of 21 Posts
