You need to slacken off the chain tension otherwise you wont get the chain off. I don't want to come over too patronising, but it isn't exactly rocket science. Buy a Haynes manual maybe?Hi guys I’m about to try removing my rear wheel tonight so o can remove the fender, is it just a case of loosening the the 27mm bolt and taking out the spindle or do I have to do anything with the chain tensioners and calliper?
So I’ve been used to single sided swing arms for the last 6 years so not had this trouble before.
Thanks
Rocket science it is not...but no need to do anything with chain tension. You are just creating more work.You need to slacken off the chain tension otherwise you wont get the chain off. I don't want to come over too patronising, but it isn't exactly rocket science. Buy a Haynes manual maybe?
