Traveler, if the piston was siezed you make a point, however this isn't an antique caliper with mung fluid, it's off a new bike and the last thing you want to do is lose fluid from the system. The pads look fresh in the photo so the only thing necesssary was to push the piston back in to seperate the pads for reinstallation. He was able to so that based on his second post quite easily. The amount of fluid in the system is dictated by the pad's depth. As the pads wear the level in the reservoir drops. When it looks like you need to add fluid (barring a leak) you really need to change brake pads. You should flush the system and change fluid when the brake fluid is turning brown. System flush is best done when you change to new pads.
