Triump Bobber Forum banner
1 - 11 of 11 Posts
I’m going to apologize up front if the following is an ignorant question, but I just bought a forward control kit for my BB from fatty0100 that came off of a Speedmaster. I would like to paint the rods, etc, black to match my BB. Anything I need to know??
Hi @PJStock,
Never be afraid to ask any question mate, no one can know everything and we are all here to help. I'm alway asking daft questions...:eek:
This may or may not be of help.
I had my footboards/controls powder coated. The only issue I had is when reassembling the main spindle/pivot point locked up when I tightened them. This was due to the thicker powder coating. It was an easy fix as I just added a washer on both sides and now both the brake and gear change pivots are free and easy.
Hope that helps,
Cheerio and good luck,
Thanks, Roy. I appreciate the encouragement. I was a HD rider for years, and I have to say the HD forums were not nearly as friendly as the Triumph forums. AND when it was discovered I am a female wrenching on my own bike, it was even more brutal. Totally unnecessary!
My other question is I planned on using my BB pegs, shifter and brake pedal. I’m assuming that’s not a problem??
Definitely go with powder coating over painting them. It’s more durable than paint. The stock BB pedals look like a satin black finish.
Hi @PJStock,
Your are most welcome, happy to help. I'm afraid I can't help with your question as I have no experience with the pegs your referring to. However I can say that you will find NO discrimination on this forum, a nicer bunch of riders would be hard to imagine. After all, I'm a rather dodgy eccentric Englishman in the US and everyone far and wide tolerates me..:surprise:
If I may indulge your patience a little further, I would like to relate the first lady biker I came into contact with. As a teenage (17) we were riding small bikes on learner plates (in the UK) and there was an older lady (probably around 40's which is not old now I'm in my 50's) in our town. She was always clad head to foot in her black and white leathers and rode a BMW combination, both bike and sidecar were also black and white. The whole outfit with her riding was very cool indeed. You can imagine how impressed we all were when she told us the reason she was riding a combination was due to loosing a leg in an earlier motorcycle accident.
All us youngsters thought she was the coolest 'real' biker we had ever met.
Have you considered powder coating them yourself? If you think you may have a lot of small items that you want to powder coat, the cost of the materials/tools is pretty cheap. Not hard to do at all and there are a lot of how-to videos.
Not sure where your located, but harbor freight, yes harbor freight has a great powder coating gun. I’ve used it a ton on my bike. It’s easy to use and works great. Typical of all harbor freight tools you might get a bad tool, but you can just return it. That’s what I did. First one I bought had a bad ground on it. Returned it for a new one and have had no issues since.
Just throwing this out there more for conversation than anything. Yes, powder coating is a good way to go, either professional or yourself as others have stated. If you can afford it, go for it.
Alternately, you can get excellent results from a rattlecan that will be nearly as durable. I'm the king of ratlecan painting, and have done so on my bike. The key is prep work.
Start with a fine grit sandpaper to "scuff" the metal. This will give the surface a "tooth" that will enhance adhesion.
Put on some good latex or nitril gloves and clean all of the parts with Acetone and a clean/fresh rag. Place parts in a clean, dry place.
Use a quality metal primer (in a can). Give a series of light coats onto the metal and allow to dry.
Use a quality paint. Give several light coats onto the metal for an even coat - allow about 20 minutes between coats. Final coat should dry for 48 hours before handling any serious way.
Total cost is under $30.
This is what I was looking for. The cost is not the problem. It’s the convenience. I’m impatient and really don’t like to wait for things to get done. And I’d like to give it a go myself out of pure principle.
There's some truly abysmal forums out there, but this one's great. I was also fortunate to have an equally great experience on one of the sportster forums... I would never have been game to start working on my own bike without the guidance, problem-shooting and encouragement of people on that forum. And it turned out that I really enjoy it... the Ikea Effect :smile2:
I don't know the answer to your question, but what I often do when I'm trying to swap out parts is check out the online parts manuals. They have exploded diagrams of the parts and the part numbers. Perhaps see if the pegs and pedal are the same part numbers between the two models. For Triumph parts diagrams I use Fowlers database, though there's a few places that have them available online.
Good advice from David... and if you like a pictorial/ video tutorial there's heaps on YouTube etc. I like this one - Motorbike re-spray with spray-cans - Autopower Car Paint Centre
Just something to note with painting vs powder coating is durability on parts that are likely to get pelted with stones etc. I sprayed forks on a different bike a while back and with them being on a vulnerable part of the bike they got stone chipped very easily. I ended up getting them powder coated and they've held up better, though if it chips now it'll probably peel off a bit like an eggshell. Of choose it may have been that my initial paint prep wasn't thorough enough :rolleyes:
Good luck with it and keep us updated with how it turns out!
1 - 11 of 11 Posts
