1 - 3 of 3 Posts
I noticed a bit of rust forming on the front of my exhaust headers so figured this weekend was a good time to give my exhaust system a coat of ceramic high temp paint.
Saturday morning I removed both exhaust systems and got to work sanding them down using a steel brush and sandpaper. Put the first coat on Saturday afternoon and then left them to dry properly overnight.
Second coat Sunday morning and then started reassembling everything. I was as careful with reassembly as I could be but the process caused a few marks so where these occurred I covered up the surrounding area and touched up around the mark with more paint. After everything was back together I ran the bike off and on for about an hour to cure the coating and took the bike for a 30 minute ride.
Before and after pictures below. I think it looks better and is hopefully better protected against rust and stains.
Did you use primer first??....I did the same thing on my BMW R9T initially It looked good but didn't hold up to well , rock chips and just wear and tear took a lot of the paint of , ceramic coating Is the way to go . Hope you have better luck than I did . Looks good though .
1 - 3 of 3 Posts
