1 - 3 of 3 Posts
I already have an X Pipe installed and I just got the Mayhem Shortys in, when I went to fit on the shortys I noticed they are not flared on the end to reuse the V band clamp? I see that they slip inside the X pipe, guessing I just need to lock them in with a T clamp and it should be good? Couldn't find any install instructions to see if anything additional was needed for the install. Anybody got any input on this? Thanks
Discussion Starter · #3 ·
Should be able to remove the parts from the stock muffler and install on the mayhem. There is no flare on the pipe side, just the ring and gasket
Install is on a 22' bobber, no gasket was used from the factory when I removed the stock pipes. sealed in placed with V band clamps. Also, I check the Mayhem pipes with the stock cat and it also slips in and fits a little loose.
1 - 3 of 3 Posts
