Prob the wrong section of the forum...apologies...
Took Scoot out for a nice warm up (30F here) and to test out the new Motodemic headlight in the pitch black...
Low beam seemed washed out, high beam was in the clouds.....sounds like I need to adjust the headlight?
What is the norm for a bike headlight angle, say on the flat and pointing at a garage door, and at what distance?
The active portion of the light was great! Though I will assume cast out farther than it should be based on my presumed headlight level.
Appreciate the assistance......I guess I could go sit with some tools on the road and adjust....
Cheers!!!
Discussion Starter #2
Google...25 feet away, top part of low beam 36 inches up. High beam, same distance centered on 36ft high line.,...I'll measure and see how off I am...
My factory halogen was much the same. I dont think they did a great job of checking it pre delivery. 30F! Yikes, that's way below my comfort zone. I admire your dedication to the cause.
After adjusting, and short frozen ride, I think I still need to angle it down some. Low beam is great, but high beam still throwing high.
Pics are 25ft back, tape is 35 inches on garage door as opposed to 36 to account for garage apron. Maybe I should have accounted for more hgt on the apron.
More to come I guess....
Hmmm, I have always just measured straight up from the ground to the center of the headlight while the bike is upright and me in the saddle (so obviously it helps to have another person but I've also done it myself). Put a mark on a wall 25 feet away at that same height measurement. Then put the light on high beam, sit in the saddle and aim the light at the mark. On high beam, I make the center of the bright region centered on the mark on the wall.
I get good illumination on both high and low and I never get flashed by oncoming drivers.
Yah, I had the Queen on the bike while I did this. I think that I just didn't drop the beam low enough.
