Finally finished cleaning up the rear end. Removed the stock rear lights and plate holder. Replaced w a vertical mount bracket mounted to the axle. Replaced the turn signals with some amber LEDs from Monsterbright. Made a little cover to hide the gaping hole in the fender. Going to back lite it with some green LEDs. Got some wrap-around signals for the front. Next is the T100 headlamp swap, my dealer had a used one in stock and it's on the way! Also, I've stripped and cleared a small ammo can I'll be mounting to the swingarm on the left when the mounting hardware gets in.
