Can someone confirm if this plug is used for License Plate Light Plug Ins? Does this disconnect? Is this Male / Female?
If you remove the Blank, will it be a Female?That is the plug I use for my license plate light. It has a blank in it that you need to remove
Yes it’s the female end.. it’s a switched live so it’s only live when the ignition is on.If you remove the Blank, will it be a Female?
Space is so tight, I don’t want to damage the plug trying to mess with it or removing incorrectly
figuring out what this will plug into.If you're just plugging a side plate light harness into the plug its very simple, the difficulty is that the plug is difficult to manipulate unless you have very small hands.
What you struggling with?
Mine does. The picture above posted by Jaho shows it.🤔Euro bikes don't have the additional connector apparently.
Thanks for the feedback back everyonefiguring out what this will plug into.
I admit to Ignorance on my part, as that plug is not shown on the OEM wiring schedule and was just quoting the comment (on Jaho's original post - August 2022) from a Czech owner whose dealer advised. And yes, all my switched ad-hoc mods are wired into that Yellow conductor from various locations of convenience.Euro bikes don't have the additional connector apparently.
