1 - 4 of 4 Posts
A bit of info i learned from the Bobber Facebook group:
The flash rate is CANBUS controlled & can be accessed and changed via the instrument panel (on the speedometer); you can choose between 4 types of ¨flashing¨speeds.
I believe the default is TYPE 2 and i am now using TYPE 4 with my bikebrothers/highsider multifunction rear lights + ABM LED mini front indicators.
It is so nice to have this option as my indicators are now flashing at a normal speed as opposed to ¨too fast¨when i was in type 2 mode.
With the ignition in the off position, push & hold the ¨i¨button on the left hand side.
While still holding it in, turn the ignition to the ON position.
Don´t let go of the ï¨button until the TYPE-2 appears on the instrument diplay screen. Now you can let go and scroll through the 4 different preset indicator speeds.
Hope this little tidbit helps :)
Good to know. I wonder what other functions can be accessed, such as 12 or 24 hour clock mode?
I’m looking, but have yet to find a hack for the 12/24 hour clock conundrum... :confused:
manipulation is impossible :crying::crying:
1 - 4 of 4 Posts
