New front brake caliper is a Pretech P824. It bolts directly on. It is a 6 piston model that only required new brake lines. Bleeding the front brakes was a pain. Mono shock is from the German company Wilbers. Model 640. Spring preload is adjustable with a spanner wrench, rebound is adjustable as well. Both can be adjusted on the bike with the seat in place. The only USA distributer is Beemershop.com. British Customs drag pipes. I DO have the cat in place. I can say that below 2500 rpm they are about as loud as the original pipes. Above 3000 rpm they really come alive! I also installed a brass gas cap from A&J Cycles. The last thing was to drill out a little larger the pin for the high bars. This gives more than enough adjustment for me without compromising safety. Very happy with all these additions. I'll report back when I have a few more miles on the front brakes.
