1 - 19 of 19 Posts
Hi everyone, this is my first post and unfortunately not a happy one.
Someone has attempted to steal my Bobber Black. As a result the ignition barrel has been destroyed.
Does anyone know the cheapest way to fix this? Can you get a barrel from Triumph to match your key?
Thanks in advance
Rab
Sorry to see this.
I agree, best to go to a dealer and see what they suggest.
Welcome to the forum.
There are genuine ignition barrels on ebay but as everyone has said the dealer will be best with the damage the rats have caused.
Thanks in advance
Rab
Hey Rab! Welcome!
Wow That Sucks!
In theory, I think you should be able to get one relatively simply. But, getting it changed out however, might be a little more involved.
It's just a guess on my part, as I haven't had to trace the wiring, or do anything else with the ignition for that matter, but I believe it plugs directly into the VCU, which is buried in front of the swing arm.
You shouldn't need to worry about the keys though. Did you receive a small tag with the keys, when you bought the bike, it would have a key code stamped on it? If you didn't, Triumph may be able to come up with it, via your VIN. Then it should just be a matter of your dealer, or part person, contacting Triumph and getting a replacement ignition module, with a tumbler to match the keys sent to them.
I think the rest of that assembly is just a proximity transmitter/receiver module with the key tumbler barrel inserted inside. The decoding and acceptance part should be done by the VCU. In short, the part you need to replace shouldn't care what key you use as long as the tumbler is right. It just transmits and receives the query sent to the key, and passes it on,,,
I think.. I could be right out to lunch! :smile2:
Still Sucks though....:frown2:
I hate to say it, but you might want to file a claim with your insurance if you haven't already, it might get expensive..
I hope you will keep us posted, I am curious as to what needs to happen!
The plastic ring around the ignition is where the antenna for the immobilizer is located.By the looks of the pictures it gone even with a after market ignition barrel you will need a new ring antenna and programming, best bet to fix it all is the dealer
Sorry to hear this Robert.
Would you mind telling us where your bike was parked i.e. in your garage - on the street etc?
Its a dealer fix because you need a Star machine to link the keys to the bike.
Also keep in mind the ignition is not the only place on the bike that uses that key, steering headlock and gas cap. So if you just replace the ignition barrel and key with after market you will still need your old key
Discussion Starter #11 (Edited)
Thanks everyone,
I'm waiting to hear back from the dealer if they can get a lock from Triumph to match the key.
The guy I spoke to today didn't seem hopeful.
@Great Black North do you know if the immobiliser antenna need to be coded to the keychip and ECU?
I'll keep you posted with progress.
Have you looked into going Keyless could work out cheaper.
I have it on my Bonnie only need to have fob in my pocket.
That's a lousy way to start on the forum. There are low life people everywhere. So sorry they caused this damage. Hopefully, it will all get sorted out quickly and you'll be on the road again.
Thanks everyone,
I don't think so, But that's just a guess, I believe it only acts as an access point for the immobilizer and the key to communicate.
Those who've done the air-box delete will tell you the ignition switch wiring harness routes to a connector under the left side filter. It's the grey plug in the pix.
:laugh: Done the air box delete and did not know that! Its a good day already, learned something new today!
Discussion Starter #18 (Edited)
Update and good news
So I rang my local Triumph dealer and they recommended I buy the whole lock kit, new petrol cap etc... at over £500.
Wild money so I just ordered the lock with an uncoded key @ £150.
I got it on Friday and connected it straight up and thought if I had the new key in the ignition and the old key beside it the reader would pick it up and send it to the ecu. Not the case!
So then I removed the barrel from the new lock and replaced it with the old barrel. Connected it up and Bobs ur uncle, it started first kick.
Thanks for all the help guys and I've just ordered some pod filters seeing as I have the airbox out!
1 - 19 of 19 Posts
