The forum eagerly awaits your report on this topic! Most of us that state what I did as a repeat of what others have said.I have a set of pipes like that to go on but haven't had the chance to put them on. I'll let you know about the torque afterward.
I don't see how you'd lose much as the x-pipe versus the straights well are pretty much the same thing. I've spoken to several people about it and they told me the amount of torque loss on an engine that size is negligible. They say you won't even notice the difference.
I think this is right.... as the engine probably does need some back pressure to work at optimum efficiency. I would assume this balanced system would help with that.If you get rid of the cat and don’t want an x-pipe then you’re probably going need a set of balanced headers like these for the Thruxton.
I do get some blubbing and pops, as RPMs come down, but have not experienced full on back fires. (TEC Xpipe and stock mufflers)I think this is right.... as the engine probably does need some back pressure to work at optimum efficiency. I would assume this balanced system would help with that.
There are reports on this forum about those with cat deletes and high flow exhausts experiencing 'pops' and back firing. While these sound really cool, everything I've read about installing aftermarket exhausts tells me that's the sound of an engine that isn't running as well as it might. There is a limit to how much the electronics on the bike can adjust to:frown2:.
Have one on order for a Thruxton R customerHmmm... Hopefully this supercharger becomes available for the Bobber. Muahahahaha!!!!
The Bulldog - Supercharged T120 Thruxton R ~ Return of the Cafe Racers
That's the answer that I have been getting from manufacturers but I can't figure how a bend can make too much difference. Maybe a little back pressure but isn't what two strokes require.Apparently the way the motor is mapped and setup, it actually requires the cat or Xpipe or it will lose a significant amounts but of torque.
I think it is more about the shared back pressure - each side connecting in some manner. cat, xpipe, harmonization pipe.That's the answer that I have been getting from manufacturers but I can't figure how a bend can make too much difference. Maybe a little back pressure but isn't what two strokes require.
Call me cynical but I think I that would be my response to a customer if I had invested money in producing an 'x' pipe. :wink2:
The reports so far...as few as there have been, and as faulty as they may be...seem to show the bike work easily adjusts to cat deletes and typical mufflers. It's reportedly when you delete the cat and run a straight pipe that you start to hear signs of engine inefficiency. How much inefficiency is unkonwn as no one, as far as I know, has tested any of this on a dyno with our Bobber engine. Until that happens, this is all somewhat internet legend material.I do get some blubbing and pops, as RPMs come down, but have not experienced full on back fires. (TEC Xpipe and stock mufflers)
Impressive, but how is it tuned. Triumph can do all of the work in house, but what do us pleb's have to get the job done. PCV not the answer, IMOHmmm... Hopefully this supercharger becomes available for the Bobber. Muahahahaha!!!!
Im afraid to ask... Most of my vehicles are turbo or supercharged. Im a fan.Have one on order for a Thruxton R customer![]()
