Sorry for the dumb question........the Haynes bobber manual is for 2017, would this cover a 2018 bobber? Pretty sure 2017 and 2018 are the same bikes but just wanted to make sure, thank you.
The majority of the manual is applicable to the 2018. However, there are some minor changes that won’t be reflected in the manual such as the headlight wiring. In the 2017, the connector is a standard H4 and is located in the bowl. Whereas in the 2018, the connector is different and is located under the tank.
Are you sure this isn't just for the Bobber Black? My 2018 original Bobber has the headlight connector inside the bowl.
It definitely isn't applicable to the Bobber Black, I contacted them a few months ago directly to see if they would add Bobber Black to Manual. At the time it wasn't included and no plans to.
