1 - 4 of 4 Posts
I have the mini apes, but would like them to be a bit taller. I don’t really want to buy taller risers since the Triumph bars and riser have the little pin and hole to help look the bars in.
Just wondering if anyone has used any extensions. There’s a 2” tall set on revzilla, but not sure if the will fit right. The Triumph risers have that little flare at the base.
Any info would be appreciated.
What will you use for cables and wires?
Another guy on here said he had the mini apes with the cable kit. He added 3” risers and the cables still worked.
I’m thinking about using aluminum rod cut to about 2 1/2” long and use those as extensions. They sell extensions, but most are made for Harley’s and the diameter is too small. Would look funny.
1 - 4 of 4 Posts
