Gila, which ever you are using try the other one, and if you always use the same brand or station use something else! What is the temperature and humidity when you are having the problem?
Gilda let me add my two cents with respect to your engine quitting when you pull your clutch in. This happened to me twice about two months ago. Took my Bobber to the dealer and they ran a diagnostic and found nothing. It did not happen again for another few weeks. But here is what took place. I pulled my bike into my garage pulled the clutch in and the engine quit as it had done before. But this time I sat on my bike, started it with kick stand(side stand down) and then pulled it up, the bike quit running. I did this four consecutive times and the engine quit when I pulled the kick stand up.Thank you for your answers. I also use 95 but now they told me to try to put 98 to see if the engine shutdown problem when I completely shut the Gas and pull the clutch, disappears. I do not think it will change but I try.
If someone who goes off the bike writes what gasoline we use maybe we can figure out something
Will do and I hope that is the case as well!Interesting!
Let us know what the dealer says. I hope it really is something that trivial!!!
Gila sorry I misspelled your name in the lead off of my original post.Gilda let me add my two cents with respect to your engine quitting when you pull your clutch in. This happened to me twice about two months ago. Took my Bobber to the dealer and they ran a diagnostic and found nothing. It did not happen again for another few weeks. But here is what took place. I pulled my bike into my garage pulled the clutch in and the engine quit as it had done before. But this time I sat on my bike, started it with kick stand(side stand down) and then pulled it up, the bike quit running. I did this four consecutive times and the engine quit when I pulled the kick stand up.
Our motorcycles are equipped with an interlock system to prevent the motorcycle from being ridden with the kick stand in the down position. My problem was the engine quit when it was in the up position.
I called my dealer and they seem to think the sensor could be lose or faulty which could be a contributing factor to causing my engine to quit when it does as I have described.
I have an appointment with the dealer next week and will let you know what I find out. Sorry for the lengthy post but wanted to let you know my experience and if we are lucky the culprit could be this kick stand sensor.
