1 - 11 of 11 Posts
I recently received and completed the installation of the Forward Control Kit from Free Spirit. I have a 2018 Bobber Black that I received delivery last month. When riding the new Bobber, I noticed my right heel kept drifting aft and was resting on the heat shield of the exhaust. My concern was I may create an ugly scuff or wear point in no time.
A solution would have to be a in forward control kit. The one on the 2018 SpeedMaster I saw in the showroom of the Triumph dealer did not exactly look OEM. No disrespect meant, but it looked to me as an add-on or after thought.
Then I discovered the Free Spirit Kit. I communicated with Brian at A&J Cycles to verify the kit would work with the 2018 Bobber Black and Brian confirmed it would. Placed the order that day. A&J provided a 5% discount because I found him through the Triumph Bobber Forum. The cost of the kit is a little over 5% of what I paid for the bike. A&J provided free shipping. I believe very reasonable for the quality. Once you see it and hold the components in your hand, you will understand what I mean.
The kit is well engineered, has several adjustable positions and very robust construction. The brackets are aluminum and black anodized. Is suits the Bobber Black very well. Installation documentation is excellent and straight forward. It took me about 4 hours to remove the OEM controls and install the Free Spirit controls. The left side, the gear shift, it pretty easy. The right side, the rear brake pedal assembly is more involved. They came up with a really KOOL way to extend the brake fluid hose in combination with a pressure switch to activate the brake light. The need for a switch at the pedal is gone! Well Done Free Spirit.
After a test ride, certainly no heel/heat shield issue, in addition, riding comfort has improved in my opinion.
Attached are some pics. Pic 1 Kit from Free Spirit, Pic 2 Gear Shift, Pic 3 Brake Pedal, Pic 4 Brake Pedal CU.
Also a shout out to Brian at A&J Cycles for the info and maintaining communications about delivery status. That kind of support is refreshing!
AirMark in South Alabama, Really Good Riding Season is Just Around the Corner, Can't Wait!
Great write up and thanks for sharing.
As a taller rider I’ve been wondering/considering forward controls as an option but thought first and await the arrival of my Bobber Black before pulling the trigger.
By any chance would you mind sharing your own height and if at all possible could you get a shot of you sitting on the bike to demonstrate leg/foot position?
Cheers,
Mike.
Hello Mike, here you go,
I am 6 feet tall and my inseam is 32". The forward controls gives me a feel of more like a cruiser. See pic.
Also both sides have several options as to where to place the pedal assemblies. I have my Bobber seat all the way back and the Free Spirit Controls all the way forward. See pic of right mount options. See pic.
Mark
Mark
Hey Mark,
That’s really kind of you thanks!
It does look like a really well put together bit of kit and I love how adjustable it is. I’ll see how I get on when the bike arrives and I’ve got a few miles under my belt but if it proves to be the case that I’ll need forward controls I’ll at least now know which ones to go for :grin2:
thanks for sharing :wink2:
explanations and photos; ideal for those who want to do the work.
Thanks for the write up. The kit looks really good and glad to see the parts are all black (as i remember Freespirits first model was silver).
Does moving the feel forward increase the pressure on your coccyx (tailbone)?
Just wondering, as extending the knee forward can casue tilt in the lower back.
Good question Eisen77. I will be able to figure that out after I get a chance to ride. The best part is, a seat adjustment and or foot control fore/aft positioning could improve your personal comfort. That is all possible because of the Bobber seat and the Free Spirit foot controls.
As luck would have it, I am finally getting a break in the action (work and day job) and could have a day or two to ride. But alas rain and wet roads are in the forecast for the next 3 days. Not surprising as we get 60 inches of rain a year here in South AL.
Mark
Have you got a picture of foot on left peg also?
1 - 11 of 11 Posts
