I definitely thought of that but there is no way to mess up the left/right (nice work on Triumph for making the sides different and easy to tell apart) since the bolts are different diameters and therefore impossible to mix up.
Funny
Sigh, finally got a reply from Matris, another example of "Blame the Customer" LOL
The biggest problem is that the bolt receptacle is too shallow (as
@atomsplitter also discovered) and you have to cut off the bolt in order to make it fit. Lubrication doesn't make a bolt shorter or the receiver deeper.
Okay so completely ignore my point, that unless you lathe the oil lock piece the base won't fit all the way in and the forks end up 4mm different length.
Yeah, I have a lot of spare time and this is how I have fun, making up issues that don't exist. The professional mechanics at Monkey Moto and Superplush Suspension can disagree with you on that. (LOLOL)
Really makes you want to buy Matris again right? I can say this debacle is exactly why I switched to Nitron for my Ninja and will not be buying Matris again or recommending them unless they admit these issues and update their instructions to show that these modifications are required. It's just dishonest to say your kit is "drop in with no modifications required" when you need to use a grinder and lathe to properly fit it.
