1 - 2 of 2 Posts
Went to do a 12min tune ran at idle for 30 min coolant pissing out but the fan didn't come on, Today the Triumph dealer had a quick look plugged it in and the fan was working so no fuse or connection problem. So am thinking the coolant temperature sensor. Anyone know how to test if it works before I replace it?
Make sure the radiator cap is on properly / intact first.
The dealer should be able to give you the specified resistance between the terminals at a set temperature
1 - 2 of 2 Posts
