I'm swapping on a pair of Trident exhausts and I noticed they do not come with new gaskets. I thought that might be the case, so I checked with my dealer about replacements. They can order them obviously, but I'd like to get a set sooner rather than later. The exterior diameter of the pipe is 1 5/16". The factory part is PFKL2637170 but there are no specs for it. Anyone have any luck with a generic exhaust gasket donut? If so, what did you use?
I'm on my 4th set of pipes (and have swapped back and forth a few times) on my bike not to mention an x-pipe on and off twice, and have never changed the seals/gaskets? unless you damage them you shouldn't need to change them..
Not so! The header gaskets are made of soft materials so that the mating parts will seal and prevent air leaks. I can't imagine that different pipe flanges will have the same shape/surface and therefore a new set is recommended.
Not so! The header gaskets are made of soft materials so that the mating parts will seal and prevent air leaks. I can't imagine that different pipe flanges will have the same shape/surface and therefore a new set is recommended. Chico
Recommended yes but not always necessary, if I did not have new gaskets handy I would not hesitate to reuse the old ones rarely had problems.
I ordered a set from British Customs (along with a bunch of other stuff) yesterday. When they come in I'll do some measurements and see if I can source something familiar from a muffler shop for when I swap back (or if someone else wants the specs).
My gaskets arrived. They're just the factory gaskets (part T2201094). Apparently BC keeps a stock on hand, probably for you to buy alongside their exhausts (or maybe they include them for free). Anyway, here are the specs:
1 in (25mm) long
1 17/32 in (39mm) outer diameter
1 1/4 (32mm) inner diameter
Guessing they are nominally 1/4" thick. The BC price is pretty fair.
