61 - 80 of 83 Posts
· Registered
2015 Bonneville T214, 2022 Bobber Gold Line
Any andriod tablet with at least 2GB RAM. Got mine off ebay for $55 it was a refurbished dragon tablet.
Dont need a cable just get OBD Link LX uses bluetooth.
I've been searching. This worked out ok for you? The tablet I mean. The tune ecu talks about needing 3 or 4 GB now, but I see plenty of people using two.
· Registered
Is there issues with claiming warranty and having a DNK tune installed?
Not that I have a warranty issue bike still hasn’t landed but would like to know.
Can you flash it back and Triumph are non the wiser?
You can flash it back before taking it in. I would under warranty.
· Registered
I was looking at system requirements on the tune ecu web site. They said that an (Android Go) doesn't have enough memory to run tune ecu, I'm in the process of returning the tablet I just purchased. Back to the drawing board! I would probably be money ahead sending the ecu from my bike to DNK. From what I've read, you have to remove the swingarm to get to the ecu on a Bobber! And the hits just keep on coming.
· Registered
This is what i got. I offered $55 and the seller accepted. 3GB Ram. Try this out!
· Registered
So you were able to install tune ecu and install the DNK tune on your bike with this device?
· Registered
· Registered
Correct me if I'm wrong but I believe there is a "flash counter" that goes up every time it's flashed so there is a bit of a breadcrumb there if they look at that.
Now in the mapping screen, I’m getting this message at the top left corner tuneECU (unregistered). I just updated the firmware on the OBD2 lx, Made sure I have the latest version of tune.ecu. I’m losing my Neanderthal mind here!
· Registered
Stop the presses, the old technically challenged idiot finally got all the right buttons pushed and got the tune to load! Only took me three days after I received the email from DNK with the tune file. Oh yeah, and six months of research!
61 - 80 of 83 Posts
