Just installed Rizoma Club L signals. Love how it streamlines the front of the bike. The stock signals are way too large for the bike.
A&J Cycles in NY sells them. https://www.ajcyclesny.com/triumph-bobberLooks great! Can you send a link to vendor? Where to order? And can you provide install details. Thanks much.
Stu
I dig the grate on the headlight...Just installed Rizoma Club L signals. Love how it streamlines the front of the bike. The stock signals are way too large for the bike.
we used to call them chip-fryer baskets >I dig the grate on the headlight...
Got it! Thanks, man!A&J Cycles in NY sells them. https://www.ajcyclesny.com/triumph-bobber
I bought them at Santa Monica Motoclub out here in California. They are the Rizoma Club L signals.Looks great! Can you send a link to vendor? Where to order? And can you provide install details. Thanks much.
Stu
Brandon, Very good post and helped a lot. Thanks, Bro.I bought them at Santa Monica Motoclub out here in California. They are the Rizoma Club L signals.
Install was very easy.
1.Remove old signals and cut wires. These are not plug and play
2. Mount new signals using whatever brackets you want. I?ll post what I used.
3. The OEM signals are only blinkers and the Rizoma are blinkers and running lights. The OEM has 2 wires. Black (ground) and white (signal). The Rizoma has 3. Black (ground), red (signal) and white (running)
4. The OEM headlight has a running light in it. It?s a yellow wire. Depending on your situation you will need to splice into that wire with the 2 white wires from each signal.
Note: I believe there is also some running light wires not used under the gas tank. You will need to remove tank to access if you want to go that route.
I soldered all my wires and shrink tubed. The whole install was very simple and only took a couple hrs max.
Also I had to drill out the smaller middle hole in this bracket so the signal would fit. They are aluminum. Very nice bracket. Worked great. I had it for my headlight.
Let me know if this helps.
