I very carefully measured the chain slack at its low and high point.
with top chain tight I came out with a 1.5" slank measurement - after first 415 miles of conservative riding.
This is my first time measurement. I tried to use the spot on the chain that had the most movement but was still readily accessible.
Manual (p.79) says chain slack should be 1.02 - 1.3 inches (22mm - 33mm) so I'm over at around 38mm.
As a side note. These wrench sizes would seem to do the trip for tightening the chain - adjuster bolt and lock nuts.
wrenches for chain adjust: 1 1/16", 11mm, 12mm (not perfect but std sizes
