1 - 15 of 15 Posts
Just a few more farkels ...Brass engine cover bolts , caps for engine bolts , brass gear shift . I used O rings on the gear shift used loctite to keep them In place , just trying to save my boots .
Does the brass cover bolts allow the torque spec? Brass stretches (depending on alloy makeup) like aluminum I believe.
I believe the torque setting Is 8nm , the bolts are alan heads I didnt have a alan socket to fit them just an alen key so I couldn't torque them down , But I think I tightened them way past 8nm .
Fair enough. Way past is not a good judge as way past can warp mating surfaces. I'm not trying to inject a worry; probably not a concern. I would want to check as engine heat rises and falls over time to assure seal as you don't have access to a torque wrench.
I like the look! :smile2:
BTW: The pipes are badass! What/who are they or are they a custom made unit? Really want to know.
Those are Toce slip on pipes made right near me. They don't show an app for Bobbers so please do tell us more??
Your bike looks fantastic. Congratulations and well done. I agree with the other comments, those pipes look amazing.
Thanks for the kind words guys....Toce don't make specific pipes for Triumph bobbers and I wasn't about to cut up $760 worth of pipes so I bought a couple of off Amazon for way less $ they are made of heavy grade aluminum very light and well made I would not have put them on my bike If they where not and sound amazingly good , So a cut off tool or grinder and a welder are needed . If you can weld Its pretty straight forward , The heat shield Is an aftermarket part more for the look than anything else .
Called Toce, they said this was a "one-off" and as of now not available without bringing the bike in to them.
1 - 15 of 15 Posts
