Hi,
I am upgrading, or probably, downgrading my Bobber Black LED headlight to an 7" regular headlight :smile2:. On the Bobber Black the connector to the light is located under the tank so I removed that and disconnected the light.
But does anyone know what that connector type is named? Trying to find one so I can solder the new headlight wiring to that and just plug it in instead of messing up the original wiring.
If you open up the headlight housing, you should find an H4 headlight connector plug. You shouldn’t have to fudge around with the connection under the tank. That way, you won’t have to cut, crimp, or solder any wires at all.
