1 - 9 of 9 Posts
Hi Gents,
So my front/right indicator has not been working at all for a couple of weeks. I was advised by a dealership that the connection (in the back of the headlight) may have just come unplugged.
I thought I might attempt to check this out myself, so can someone with more knowledge than I give me some advice on how I actually get into the headlight?
Note I am running a Speedmaster headlight but I'm thinking it would be the same/similar.
I had the same problem. I lifted my tank back a bit to make space to get to the mess of wires. All I ended up doing was moving the connector for the signal a bit and it started working again. It looked fine and I didn't actually change anything. Just a cheap connector plug I think. It's been working ever since. The plug is not inside the headlight.
Hi Guys,
I think? (he say's with his fingers crossed) I have fixed this.
As mentioned by Beaker, the indicator wire goes under the tank (not into the back of the headlight which I was told by the Triumph tech..!). I traced the wire and felt that perhaps it was too tight under the wire clamp (see photo). So I loosen'd off both of the indicators, undid the wiring clamp, pulled the wired to the rear a little and retightened everything back up.
This seems to have solved the problem, if so then that's an easy fix. Will monitor going forward but fingers crossed.
Just my thoughts.....I see posts here saying they just wiggled or poked around at the wires and ALL was good? If you happened to have pulled the wires lose enough to cause a poor connection, my opinion is that finding that poor connection and making it tight or whatever is in order. I’m not testing people’s competence, but maybe I misunderstood the postings? ?
Have a great day! Oh.....Happy Mother’s Day to you MOTHERS out there!
Hi forjox,
You are totally correct of course. As I'm not too mechanically minded and my nearest dealer is a distance, my plan is/was to get this working and then on my next service/maintenance have a professional take a more serious look at it while other work was being done.
Will take a ride today and she if all s working okay.
1 - 9 of 9 Posts
