Had a lot of fun having the BB kit installed this Saturday.
Very well made, professionally painted, easy to fit and looks fantastic (if i do say so myself :grin2
The all in one brake/position/indicator lights are small & really bright!
Markus @ BB was a pleasure to deal with and made sure that the whole process was smooth and efficient.
The numberplate bracket was cut down to fit EU specs and they also made a ´plug & play´connection for the harness, so no splicing or cutting was required.
Cables are kept to an absolute minimum and are easy enough to hide and zip tie to the frame.
I also removed the RapidBike A/F module and replaced it with a BoosterPlug.
Throttle response feels amazing - even smoother and more electric like than with the Rapidbike. There is ALOT less popping under decel and low speed handling is vastly improved. The engine definitely prefers the BoosterPlug over the RapidBike when opening the throttle from low RPM (in any gear). I also feel that holding a constant throttle (i.e motorway), the bike holds its speed much steadier and does not ´hunt´.
After 100km of uphill/downhill, curvy, slow & fast mountain roads and 100km on motorways - i can say its a great product and i´m leaving it on. The guys at BoosterPlug were also great to deal with and had my plug shipped out immediately.
It took less than 5 mins to install & like others on this forum, i installed the temp guage at the rear of the bike.
I finally got around to removing the front fork reflectors. Simple enough with some heat and brake cleaner/fluid to remove the residue.
I also managed to test out the titanium draggers. They work exactly as advertised and GMAN is about to get some new orders from some fellow riders here in Mallorca.
