1 - 5 of 5 Posts
Anything I'm doing wrong? I've taken the side panel off, removed the metal strap, removed the plastic cover.. Still unable to slide out.. Any advice will be appreciated.
You have to remove the screw on the left of the battery. This screw attaches the ground/earth/negative wire. The battery will slide out so that you can remove the positive wire. You probably figured that out by now.:laugh:
1 - 5 of 5 Posts
