Triump Bobber Forum banner
Other than looking bloody gorgeous, are there any tangible benefits to removing air box? I have searched through a few threads and think I'm going to bite the bullet on this one, it looks too good I've got to do it. I was wondering if there is a UK kit that I can purchase that includes filters and some kind of cover. I am aware A&J do something, but as a UK resident shipping/Tax think it will be a non starter.
Rumor has it that the open pod filters flow better than the stock air box arrangement. Basic Physics and fluid dynamics would suggest that it should increase and, depending on intake configuration, smooth air flow, so in theory it should hold true. But to date, I haven't seen any dynamometer results (trirocket3 you got anything??) supporting that claim.
The stock air filters do not flow much air, I modified them by removing the metal mesh that covers one side, it restricts the flow, but even with that removed it held my motor back on the dyno to low 90's hp,
whipped filters out got over 100hp.
I do not know if anyone has done a filters only before & after dyno it would be interesting, but I have to pay for dyno time so will not use it up for this, But in my opinion reasonable size pods, I have seen some that do look a little inadequate (ever get that feeling) could yield a touch more at top end, but may lose slightly at low rpm, due to the way Triumph have cleverly designed inlet tracts (also exhaust but that is a different subject) for low down torque.
Would it be noticeable, probably not, but the intake sound from the pods may sound faster to some.
So no harm done, if you like that look go for it.
Funny you should mention that, I was thinking about very thing after writing the response to LLR71 this morning. I have to go for a dyno tune (April 23) and am going to be reinstalling my factory air boxes until then, maybe I will see if my Buddies at Echo Cycle will humor me, and I will do just that.
That could be really interesting, keep us posted if you could.
I didn't buy any sort of kit. I pulled all of the air breather equipment off and mounted $30 set of air pods that had a 50mm diameter flange (built for a Honda) directly to the air intakes. No need for a pipe or kit. I paid like $5 for a crankcase breather and reused one of the tubes.
A really smart job David, well done.
Sometimes we need to pay lots to get the mod we want but I also like it when, with a little ingenuity we can work it out ourselves for a lot less.
Thanks for the kind words Roy. I can always move up to K&N filters later, or some other option. I'm saving all my money for forward controls. Something I don't think I can do cheaply, regardless of my "bag of tricks". Least expensive option is the OEM Triumph kit which I have on order. :rolleyes:
