1 - 20 of 127 Posts
Has anyone begun working on air box elimination for their Bobber? On the Down and Out customized Bobber I see they've done it. I'm hoping for a kit rather than recreating the wheel.
Opening the view through the frame is the way to go for a true Bobber look.
On a separate note, I think the headlight on my Bobber is under sized. Working with my guy Mark Plazak at South Bay Motorsports, Chula Vista, California, we discovered the T100 headlight fits the space much better. Along with a set of British Customs mounting ears, I should have the light on this weekend, photos to come.
Do you mean a kit like this?
https://www.freespiritsparts.com/en/triumph/news/aircleaner-high-flow-kit-for-triumph-thruxton-1200-bonneville-t120-water-repellent.html
This is one mod i WON´T be doing.
I like the stock look (ALOT) and putting those filters next to my trousers will make for some hefty dry cleaning bills :wink2:
Also, i am not sure if they will affect the position and comfort of my long legs...
Discussion Starter · #4 ·
Got the new headlight on. Used a T100 headlight, black can with a black bezel. I used the British Customs mounting ears as well. It was almost plug and play. The running light didn't match up so I had to splice old to new. The mounting ears could be about 2mm wider. Still, very happy with the result. Here is a side by side, new and old.
I think that looks great! Nicely done!
Does look great! The other nice thing about using the T100 headlamp it gives way to utilizing a 51/2 inch LED after market lamp. I could not find any to upgrade as the Bobber stock light is 5 inches.
Great job!!!! Actually it looks better with the larger headlight. This is the way it should have been to start with. How is the lighting? I know the high beams suck as it is now.
The Bobber looks better with a larger headlight. Can you change the bulb in the T100 headlight unit or is it stuck with whatever bulb it comes with?
Discussion Starter · #16 ·
Hey MikeMAC,
Which T100 headlight did you use?
Was it the Triumph original or a replacement?
Thanks, Stoli.
Hey Stoli,
I sent the parts list to you in a private message. I think its a great mod and its not too difficult, good luck.
Mike
you knocked it out of the park with this mod! i always did think the stock headlight was a little small. now after seeing your photos and how awesome it looks (fits better with the bike), i now really notice how small the stock headlamp looks and can't stop always staring at it. this will definitely be my next mod (after i get my x-pipe). can you direct me/us to the lamp part#. was searching online for a T-100 headlamp, but didn't have much luck. when you mentoned the mounting ears could be 2mm wider, is that because there's a little gap, or the headlamp is not resting flush in between? thanks!
Discussion Starter · #18 ·
Thanks so much. From the first time I saw the Bobber I loved it, except for the headlight. Thanks to Mark Plazak at South Bay Motorsports here in San Diego, I was able to make the change shortly after taking delivery of the bike. The British Customs mounting ears are very close to a perfect fit. I'm not sure if the Bobber's forks are a bit more narrow than the T-100 or if the British Customs ears are slightly narrower than the Triumph mounts. The entire set up is just a few millimeters off. However, I was able to make up the difference over the various adjustment points and its not at all noticeable.
The parts: As you likely know, you can't just buy a completed headlight from Triumph; you have to purchase the individual parts and assemble the light. I purchased the mounting ears from British Customs http://www.british-customs.com/headlight-ears-black. The rest are genuine Triumph parts from my dealer.
Here is the list of Triumph part numbers, a description of each item and quantity of each needed part:
P/N T3205156
M8 bolt
Two
P/N T2796508
Headlamp with bulb
One
P/N T2706555
Spring Clip
Three
P/N T2704021
Headlight Bezel
One
P/N T3331436
Self-tapping screw
Two
P/N T2706509-PG
Headlight Bowl, black
One
P/N T2703787
Bracket Connector
One
P/N T3330941
M5 screw
Two
P/N T3555033
Washer
Two
Good luck!!
P/N T3205156
M8 bolt
Two
P/N T2796508
Headlamp with bulb
One
P/N T2706555
Spring Clip
Three
P/N T2704021
Headlight Bezel
One
P/N T3331436
Self-tapping screw
Two
P/N T2706509-PG
One
P/N T2703787
Bracket Connector
One
P/N T3330941
M5 screw
Two
P/N T3555033
Washer
Two
Good luck!!
Thanks MikeMAC!
1 - 20 of 127 Posts
