Hi Guys,
I just noticed one of my rear indicators is loose. Before I go diving into something don't understang:surprise:
Can you have a look at the pic and tell me if this (difficult to get to) bolt is what tightens these up?
If so, I'm assuming one needs to pull the whole light assembly off in order to get to it?
Happened to me twice within a couple weeks on the same indicator.
Second time I tightened everything up with loctite. Been fine since.
Unfortunately you have to take the assembly off the fender and take it apart to get the hardware.
The screw you have pictured, if I remember correctly, just holds the housing together.
Hope that helps.
