Triumph Bobber Forum
Triumph Bobber Forum (https://www.triumphbobberforum.com/forum/)
-   Electronics (https://www.triumphbobberforum.com/forum/913-electronics/)
-   -   Ignition switch connector (https://www.triumphbobberforum.com/forum/913-electronics/15441-ignition-switch-connector.html)
Retro Rocket 48 06-03-2019 03:12 AM
Need to access the ignition switch connector to install antitheft alarm. Supposing I'll need to remove the left side air-box to get at this. Yes/No.
If you've done the air-box delete, then you could probably tell me exactly where it's located.
Thanks in advance.
John 06-03-2019 03:15 AM
It I located on the top forward edge of the battery box top cover, on the left side of the bike. You will, indeed, need to remove the left side cover and airbox.
Retro Rocket 48 06-03-2019 06:41 AM
Thanks for that info mate.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
